killerbyte1985
- Sep 24, 2015
So I have two systems; my gaming rig and my media server.
My gaming rig is uses a Silverstone Fortress 3 which is a micro ATX chassis with limited airflow. I have a Corsair H80i with two Noctua NH-F12 PWM fans in a push pull configuration. The chassis itself uses a single 120mm silverstone fan to move what limited air there is around.
I want to replace the internal fan with a high airflow fan but would like it to be as quiet as possible.
My media server uses a CM Cosmos SE. That chassis has two 120mm fans in the front, and one at the rear. There is a Corsair H100 cooling the processor which uses the two 120mm fans that came with it. These fans are very noisy, and right now my server is the loudest thing in my room and the temps are not what I want (45-50 on an AMD A10-5800K)
So here is the shopping list:
4 Static Pressure fans for the Cosmos (2 for the rad, 2 for the front due to the HDDs)
2 High airflow fans (one for the Cosmos rear and one for the gaming rig).
Any recommendations for fans available locally and those which have to be imported. I was thinking of some more Noctua NF-F12 PWMs for the static pressure roles or if I can find a store that will ship to South Africa maybe some EKWB Vardar fans.
