Some tidbit from Martin was that with lower speed fans a pull is better. Something about the incoming air goes across the rad fins more evenly for better air dispersal. And push focuses the air more. Don't know if that was on his site or in a post. We have all seen the doughnut dust pattern on rads.
The MCR 320 isn't that high of a FPI, kinda medium.
Found it!
From here, in the MLL Archives:
http://martinsliquidlab.petrastech.com/Radiator-Fan-Orientation-And-Shroud-Testing-Review.html
"While I didn't complete the full series of tests, this was enough for me to see there is some emerging trends going on. The push vs. pull question appears to really depend on the fan power. I believe the gains in the 38mm showing more benefit in push is due to pressure and turbulence. At these stronger speeds, the added pressure compressing the air along with higher turbulence across the radiator in push is providing the best benefit. This appears to change however for the lower speed fan where pull actually does better. I believe at this slower speed pressure and air flow is so slow that it's simply not turbulent enough to show gain in push and the radiator performs better with the more evenly distributed air flow over the radiator that's provided in a pull condition."
