- Jun 21, 2005
Hello,
Since I got the 1080Ti FTW3 which is an open-air card my case temps raised significantly (compared to the old blower-style card).
My case is Thermaltake Armor Revo and my current setup is
(intake) 200mm case fan. Location:*1* (front)
(intake) 200mm case fan. Location:*4* (side)
(intake) 140mm Noctua NF-A14. Location:*between cpu heatsink towers (which is an old IFX-14)* (middle)
(exhaust) 200mm phanteks fan. Location:*2* (top)
(exhaust) 140mm turbo case fan. Location:*3* (rear)
Whenever I game i can feel hot air from the top exhaust mostly.
Is the current setup good? Should I add a new intake fan in position *5* (bottom)? Should I re-position any fan? For example should I put Noctua to the rear instead of cpu heatsink?
Thanks
Thanks
