- Nov 6, 2003
- Denver, CO
I was going to pick up some UV cold cathodes at SVC.com and figured I might as well pick up some cooling stuff while at it. I came across these $1.99 "Unincom multi-directional intake silent fan(s)."
http://www.svc.com/u8025.html
First off, these have slits or holes on the sides to intake from there as well. Why would I want to intake hot case air and just blow it right around inside the case?
Also, don't fans push air against the sides? The Zalman heatsinks and many video card heatsink fans rely on this, the fan pushes air away from the blades to the sides. This has got to have insanely crappy static pressure, you add any resistance to it at all and it would flow out the sides.
Yet, it states those specs: 8.658 mm-H2O
My TT SF2 has closed sides and spins at almost 5000RPM and it doesn't even do that! 8.658 is more like Vantec Tornado range!
It also says this: 1,800 ~ 3,800 R.P.M.
That is one helluva RPM range, it doesn't have temp sensing or a controller or anything.
I wonder, why would a place like SVC even sell something like this? It sounds like a scam almost to me, a worthless peice of plastic. If it really was that great it wouldn't be 1.99.
Would anyone know of any fans that put out a good amount of airflow for their noise and are real nice and cheap?
I am thinking of either this $2.99 Panaflo: http://www.svc.com/fba08a12m.html
or this $2.99 Sunon: http://www.svc.com/kd1208pts2-4-86.html
Only problem is, I didn't think Panaflo's came with the connector, I thought they had bare wire leads.
One last thing, my thermal compound is OCZ Ultra 2, not the best. I was thinking of getting something better since my tube is almost all out, is AS5 still pretty much the best you can get?
Thanks a bunch!
-0cer
EDIT: Nevermind, it does come with just bare wire leads. Maybe I will just get the Sunon instead, they seem to have similar CFM to noise, just the Sunon being a little bit faster and louder.
Thanks a bunch!
-0cer
