- Apr 20, 2010
ok with my SIG rig i have these as my fans
2 mumbo junbo fans 240mm????
2 side panel fanes standard size 140mm????
1 on each GPU
and 2 push/pull on my cpu cooler
the case is a coolermaster sniper, so i think th emumbo jumbos are staying as i would have to cut rivets to get to them???
but as far as the CPU and side panel fans go i am all ears for improvements.
since fans are cheap it wont hurt to improve what i have, and i have a nice slick fan controller, the only down side is my fan controller doesnt use Molex it uses the standard 3-4 pin attachments and one cable run has a CPU fan rig that tricks the MOBO
lets hear what you guys think i should go with, and keep in mind i want to move away from molex(weird i know)
1 on each GPU
