An external rad with quick disconnects through some holes in the back of the case can greatly expand cooling potential.
I use a MO-RA3 420 soley for my 4790k at 4.7 and 2 R9 290s. I think the problem here is OP loves his case and probably should have purchased a bigger case for custom water cooling.
Do you have extension wires for the fan wires? Those are 4 pin PWN fans. Where are you going to plug 8 of them in. You need an 8 pin block. My XSPC 140 MM fans are three pin so I used a 1 to three splitter (3 fans per splitter) attached that to a @20" extender which then pugged into the fan cable for each channel of the NZXT fan controller.Eh might as well go all out... I get to write the whole system off for work anyway.
So those parts will work okay and I shouldn't need anything else?
I see ATMINSIDE, in his Water Cube build, used a Swiftech 8 to 1 PWN splitter that apparently plugs into a sata connector.
- - - Updated - - -
Here's a link to it at PC Performance:
http://www.performance-pcs.com/swiftech-8-way-pwm-splitter-box-sata.html
I did, it is an awesome splitter.
Currently, I only own four of them...
Yes I would be using a splitter.
ATM, when you say I only need one more radiator are you saying one more 240? My CPU under load when folding hits mid 90s within minutes of starting. I think the big external would be my best bet.
ABSOLUTELY! A MO-RA3-360 is nearly the equivalent of 3-360mm radiators. Some puriest claim the MO-RA isn't as efficient but the data for the version 3 (MO-RA3) appears o dispute this.You could run your whole system off of a single MO RA3 360 PRO.
