Hi,
I'm new to over-clocking and am looking for advice on what system you would buy based on these needs.
I need a PC to run a number crunching intensive program, will crunch numbers for a few days at a time. No frills, no monitor as will RDP in.
Guessing by this page that i7-4930k is best. Is this the best way to gauge computation power for number crunching only? (Intel is recommended for my software)
http://www.cpubenchmark.net/overclocked_cpus.html
- What system would you recommend for under $1000, what type of cooling?
- I don't want to build it myself, what company would you recommend?
- I read that Sandy procs are recommended over the newer ones as they run cooler, is this true? I need the highest CPU speed possible...
Thanks in advance,
Shane
Thanks in advance,
Shane
