- Jun 13, 2007
my hard drives keep dying on me, i've gone through 3 of them so far and it's been the same problem each time.
i also started a thread in the storage section, not sure what the problem is.
here is a SS of everast and my voltages. is it fine to use that or should i get the mm out?
hope it makes sense, any ideas?
my hard drives keep dying on me, even the ones that get sent back to me after rma.
i've had to RMA my main Os drive twice now, one of my other drives once and it seems my programs drive is going to need an rma soon.
all of the drives i sent back, all had the same symptom. they would spin down and click, then spin back up. sometimes it would freeze the computer to the point of resetting or just for 10 seconds or so.
i got made at seagate and changed my os drive to wd in hopes that it would fix the issue. so far it's been fine.
my programs drive is failing by just disappearing from windows. i replaced it's sata cable but it is still doing it.
could this be a power supply issue? i've got plenty from a known brand.
850watt Enermax.
according to the psu calulator, i am only using 574watts with the system in my sig.
to me it seems it could only be the power supply messing things up.
