- Jul 31, 2004
Samba as a protocol (kernel driver) is deprecated, you should use CIFS instead. The Samba userspace tools will still work with the new driver.
Well that's kind of more confusing to me - we are talking about user-space addons in this thread, not kernel modules. Most anything with linux we'll need to assume we're starting from a distro with a reasonably up to date kernel or a properly configured custom built kernel... Unless we are actually talking about kernel configuration to start with.
That said, should we consider the user-space samba package a worthwhile addon?
Wouldn't it possibly be better to recommend GVFS? Or something other than the samba package? I don't use the samba package, and I have no problems accessing various windows shares (I do have gvfs installed which gets me the userspace support I'd require)
1 of my fav programs for linux is screen.
it lets you detatch (then reatach later) any command line program, so you can demonize any program , i think it was originaly written so you could multi task with only 1 termal open.
I used it to keep rtorrent, esniper, and fah running on my server, along with a couple of custom scripts
Just added Screen to the collection under Productivity Addons.
Mark, if you have the original creator's webpage please link it. I had a little trouble finding a decent site to provide a URL.
Screen is part of GNU.
would you be able to add esniper?
its a command line program for auto bidding on ebay items.
if you find multiple auctions for an item you only want 1 of, it will snip bid on them 1 by 1 untill you win 1 of them
you can set the wanted quantity to what any number you want.
its cool
http://esniper.sourceforge.net/
note: currently the version in the ubuntu repos is broken from ebays last update. but the debian version is upto date
http://packages.debian.org/sid/esniper
So that means that any distro that uses GNOME should already have it installed correct? Forgive me, I try to learn something new every day.
Esniper added under the Productivity Addons category. Thanks for the suggestion Mark. Keep them rolling in!
got another sugestion for you, called flexget, its for auto downloading .torrent files from rss feeds, i used it to auto dl my tv shows, so i dont forget there on
http://flexget.com/
http://flexget.com/wiki/Install
if i remember any more il let you know
got another one for the list:
prism
I quote wikipedia "...integrates web applications with the desktop, allowing web applications to be launched from the desktop and configured independently of the default web browser..."
Very nice for making a fast check to Gmail, Twitter or whatever (any) website you want.
