- Apr 26, 2009
- Athens, Georgia
With 8gb of memory you want to set yourself to the 4x memory multiplier and use the fsb (as it's called in intel) to up ram speed to the 850-900mhz range. I believe if you can get all 8 gb of that memory clocked to like 860-900 with cas 4 timings it will actually outperform the 1066 cas 5, as to whether the particular memory can do that is another thing.
also about the nb, also called the nb-cpu because it is memory controller that resides on the cpu, try getting it up to 2400+ stable. It does make up for not being able to run all 8 gigs at 1066.
Also where is muscle shoals, I was born in Dothan but have lived in Ga all my life (and family is from ga also)
