- Jun 16, 2012
- new jersey
ok i have bought everything i need for this water cooling loop. im waiting for a couple part to be delivered. im really pumped for assembly. i just want to make sure i got everything i need and want to see if you guys had any last minute tips before assembly. ive been doing a lot of case mods and planning and i think im ready.
its a one loop cpu only loop. one rad
here is the checklist
*140.2 swifttech rad
*8 feet of danger den 1/2 tubing
*Xspc raystorm cpu block + thermal paste
*8 1/2 barbs 2 rotary 90 degree. (for cpu block) 6 straight
*Swiftech MCP35X with Phobya Pump Top
*xspc 5.25 bay res
*bgears b-Blaster 140 140mm Case Fan and COOLER MASTER 140mm Case Fan
* 2-way 3 pin adapter
*silver kill coil
* psu jumper cable
* 4 automotive grade hose clamps (im putting them on the res and cpu block) thew rest are dd plastic clamps
* a gallon of distilled water.
that pretty much it. i hope i didnt miss anything.
any last tips and tricks you guys might want to share !!! : attn:
*xspc 5.25 bay res
*silver kill coil
* psu jumper cable
