- Feb 3, 2005
- Thread Starter
- #21
Excellent. Just started bleeding the loop so while it's doing that I can start creating a mount for the heatsink. If anyone has some easy, creative ideas, feel free to share
if you know how i would lap the celeron heat sink for a couple of degrees cooler.
Nice job on mounting the MCW60 ...
I was thinking the exact same thing. It has some wierd layer of foil stuck on so I'm going to lap it to get it off and get rid of the layer of paint.
I don't know where you got your info but Water Wetter was thrown out years ago. Thats pretty much the only thing thats agreed upon with additives. Personally... I Prefer Antifreeze. Its cheap, and its effective. Course, its only for corrosion, you need a biocide agent for preventing growth.Antifreeze is generally frowned upon as an additive. Use something else, like Water Wetter
nice job on the modded block bracket, i'm just wondering though how well does it press down on the gpu? also if you still have the original heatsink for the card, maybe cut the part that covers the gpu and then you can have the same cooling, maybe better since the gpu isn't adding heat. hell if you can get the water block to touch the original you might even get a full water block effect.
nice temps, personally im glad the gpu mount worked, i was a little skeptical!
So what's your highest stable "FSB" ...?True, but a few weeks ago i tried booting at 250 with the CPU multi set to 6 and it wouldn't post. But we'll see what happens when I get home and start clocking higher.
