Which version of cpuz are you using? I have also had problems with cpuz not reading correctly with my cpu and MB. I wouldn't worry about it too much it is most likely just cpuz reading incorrectly.
I got me a Danger Den TDX water block and redid my water lines. My temps dropped over 10c which is just amazing to me. Now I am having another problem. I can Prime95 this thing for hours at high clock speeds,
But when I try a PCMark 2004 test it doesn’t give me a score.
Look at the test you are failing a test that is why ther is no score.meaning you are not stable..I would lower the clock a tad and try it again..I think you may also see a weird PCI issue with that chjipset as T/C has found ? ? ?
