- Apr 7, 2009
I am looking for a replacement fan for my eVGA GeForce 6800 PCIe graphics card stock cooler. I have attached the graphics card product datasheet to this post.
I have found that many graphics card fans (often called "VGA fans") are available for purchase, especially on eBay, Amazon.com, and websites that ship products directly from China.
However, it is not clear which of all the offering is compatible with the cooler.
The cooler and fan is of the ARX Group OEM ( http://www.arx-group.com/ )
I have measured the fan dimensions, but there may be some error (the fan had been necessarily warped for removal due to tight seal with screws). The measurements are:
The fan uses three, apparently equidistant, screws to secure it.
Is the fan thought to be a standard sized fan?
Many of the fan offering are for "45mm" designated fans. After taking measurements as best as could be done, it is still difficult to determine what fan to get for a replacement.
I wherefore request assistance regarding the replacement fan selection or identification.
EDIT: I have found and attached a picture of another same stock fan ( from http://www.ebay.com/itm/47mm-Fan-Fo...US_Video_Card_GPU_Cooling&hash=item19ed295372 ).
- 47mm or 48mm actual fan diameter (blade to blade); possibly another about another millimeter for screw hole extending beyond blades
- 10mm fan assembly height
- 39mm distance between holes measured using center of holes of endpoints
- 23mm distance from holes to center
