- Aug 3, 2010
I have kind of finished my build with pics below .. My issue comes as I have a nice cooler that won't fit unless I take the top 2 fans out.. So I looking for an air cooler and I don't care if used or new but I am trying to keep it cheap.. The fans are ok but I would like to use quieter fans if possible for cheap..
Spec-
Case- Corsair Carbide Series SPEC-03 Red Steel
MB-MSI 970 Gaming AM3+ siza ATX
CPU-AMD FX-8320
GPU-Powercolor 280X
OS- Win 7 Ultimate
Heatsink-Spire TherMax Eclipse II(Won't Fit)
SSD-Samsung 850 EVO
Storage Drive-SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
Power Supply-Seasonic M12 II Bronze Edition 850W PSU
Ram-G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
Yes I modded some stuff like taking the HD cage that blocks the lowest 120mm fan..
Spec-
CPU-AMD FX-8320
GPU-Powercolor 280X
OS- Win 7 Ultimate
SSD-Samsung 850 EVO
