Budget - $2000 USD
Usage - Office, Internet, and Elden Ring. Since any system that can run Elden Ring will be able to handle the other basic stuff, Elden Ring (gaming) is the focus of this build.
I will be using my television as my monitor. It's from 2015 - Samsung 55" JS 8500. It can display 4k, but I'll likely play @ 1920x1080. If going to 4k @ 60 FPS makes sense financially, so be it. But I am not trying to spend $1500+ on a GPU for that. My old eyes probably can't tell the difference between 4k and 1080 anyway.
I've looked around here and Reddit, and am just throwing the following out as a starting point:
CPU - Intel Core i5-12400 2.5 GHz 6-Core Processor (seems to be a popular pick)
CPU Cooler - Noctua NH-D15 (it was awesome back in the day, and I am a fan, no pun intended, of all things Noctua).
Motherboard - Gigabyte B660M DS3H DDR4 Micro ATX LGA1700 Motherboard (seems common recommendation w/above CPU)
RAM - no idea
PSU - no idea
Case - Not gonna lie, kinda loving the Fractal Torrent line. Would like to get smallest that will fit parts (probably Torrent Compact)
Case Fans - No idea. Probably something from Noctua.
HDD - All set on storage drives. As for main drive, I can port over my 1 TB Sata SSD or get an NVME drive. Worth it for gaming???
GPU - no idea. Probably between a 6600 xt and a 3060 ti, yeah? No clue.
Thanks for any information. Ask away if I can / need to clarify anything.
RAM - no idea
PSU - no idea
