- Jul 7, 2010
- Wynnewood, PA
Ok so this is my first post here talking about my first watercooling build. I have read and read so its now time to make one giant post with redonkulous amounts of stuffs . So before I start listing parts and questions the general idea of the build is a two loops system. One loop will cool two 480 gtx and the second loop will cool cpu and mobo. That is where I started and now for where I ended up.
Parts for the system:
Motherboard: ASUS P6X58D
GPU: EVGA 480 GTX Superclocked Version (x2)
PSU: Antec TPQ-1200 1200W
CPU: Intel Core i7-930
RAM: CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
HD: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (OKGEAR 18" SATA 6 Gbps Cable, Straight to Right Angle W/Metal Latch, Silver, Backward Compatible with 3 Gbps and 1.5 Gbps)(Is that the right cable?)(x2)
Optical: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
Ok so thats the hardware looking at that list does anyone see where I would need to buy any extra cables or adaptors? Also whats your opinion on the system itself?
Now for the water cooling parts list. As I said before I want to do two loops one for the CPU and MOBO and another for the 2 GPU's. So I am not sure how to set up a SLI watercooling setup so some help there would be nice but before I get to more questions let me list the parts.
Case: DD Double Wide Tower - 21 Black Series Edition
CPU Block: Sugggestions? I want to use 3/8 Compression fittings on this entire build.
GPU Block: Bitspower Black Freezer VG-NGTX480 GeForce 480 GTX VGA Liquid Cooling Block (x2)
NB/SB and Mosfets: Suggestions? I was only able to find stuff for the P6T and I am going to use the P6D (Make sure I can use 3/8 compression fittings please!)
Tubing: Tygon 2075 Ultra Chemical Resistant Tubing - 3/8" ID (5/8" OD) (How Many Feet You think?)
Pumps: I have zero idea when it comes to pumps I know I want a DC one so I can just hook it into my PSU but I am confused about fittings for them beacuse i want to use 3/8 ID compression fittings and I dont know how strong they need to be so help here would be nice!
Coolant: Suggestions? I want to use colors and I dont want to just used distilled water do you guys have a certian brand or amount for this build?
Rads: Black Ice GTX360 and Black Ice GTX480 (Figure if I am going to use such a big case might as well use large rads but to double check will these two fit into the double wide? also can I hook up 3/8 ID compression fittings on them because on danger den they only offer 1/4 inch and 1/2 inch)
Fittings: 3/8 ID 5/8 OD compression fittings, do you think thats the right choice for this build? also can someone help me figure out how many I am going to need?
Res: Bitspower 5.25 Bay Reservoir (x2 for the two loops)
Ok now onto questions
1) Is there something special I need to set up the SLI on my graphics cards?
2) The ones that I threw in when I was listing parts
3) FANS, any suggestions? they range from like 6 bucks to 30 bucks I got no idea which ones are good for water cooling and how many would I need for this system for Rads and fans in case. Also whats the deal with a push pull set up like what exactly is it?
4) Any other parts that I am missing or that you would suggest
5) Fan controller, If I have like 25 fans in the system how would I set up the controller that only has like 6 knobs
6) Power button for my case?
7) T-Line? should I put one in? If so, how because I read that it makes bleeding and filling super easy
Thanks a ton! so now help me!
