- Apr 7, 2010
- CT
also for the rads i picked can i use fans that are 120x25 or do they need to be 120x38
the thickness doesnt matter, speed and CFM do. If you can get the CFM you need on a 25, then go 25, if you need 38 then go 38.
i dont know where everyone went but i have been looking around all night and i am not sure if i should stick with the asus p6x58d premium or switch to the EVGA E760 CLASSIFIED
opinons?
(everyone COME BACK)
Well the only part of my build that im missing now is my pump and then the SLI stuff for my card so if someone could help me with that, that would be great
decided to go with ultra kuze 3000 rpm fans even though im a bit upset about the no LED going to switch tubing to 1/2 ID 3/4 OD since it will give me better flow and the fittings will be easier to find
does anyone know if the p6T blocks will work on the D version of the mobo im using?
also for the board fittings if i were to buy a full board from EK would i also need to buy mosfets and NB/SB or would the full board do the trick?
https://www.sabrepc.com/p-289-evga-...hydro-copper-ftw-15gb-pci-express-20-x16.aspx
should i get one with a block already on it just to avoid the possibility of breaking it while installing the waterblock and having a broken card without a warrenty?
opinons?
Take your time. Most of these questions you should be able to figure out.
thank you
3) does anyone know about pumps?
4) How do i mount a pump or a pump mount inside of my case?
thanks for getting back to me and i am kinda novice but i really wanna get this build on the way
1) by sli stuff i mean watercooling supplies for an sli setup
2) it wont be in the same loop as my cpu the two cards will be in their own loop but the question is, is it worth the lower end waterblock for the warenty in case i get a faulty card then hook up the block and then a week later it doesnt work and im out 500 dollars?
so i think this is the pump i will be using so i will need two because im doing two loops
http://www.frozencpu.com/products/9..._18_Watt_Version_32.html?tl=g30c107s155#blank
issue is the inlet is 1/2 and the outlet is 3/8 so how would i hook up 1/2 compression fittings onto it?
gracias
was unable to find sli connectors at performance pc you wanna link me?
thanks
whats the difference between the two pumps and whats the difference between 12 and 18 watt pumps
http://www.xspc.biz/ddcres.php
resovior combined with pump top a good idea?
3) How do cable sleves work i have never really cared about cable managment so if someone has a link to a fourm post or suggestions that would be super helpful
