Hi guys...First post here. I started following the forums soon after I decided to build my own computer. I didn't really have any issues building the computer but now I'm having serious issues once running it and I'm really hoping I can get some help here.
Here are various BSOD's and other things that have happened:
1. STOP 0x0000001E
2. BAD POOL CALL
3. STOP 0x0000007E
4. PAGE FAULT IN NON PAGED AREA
5. IRQL NOT LESS OR EQUAL - Tech info on this has varied with 0x00000050, 0x000000D1, wdf01000.sys and atikmdag.sys.
6. Jagged lines across the entire screen with a freeze.
7. I DL'd AIDA64 and running the stability test caused a crash and I think made a clicking sound happen once inside the case.
8. Possibly the weirdest is that each time (twice) I've used the back button on AIDA, it's frozen my screen.
So....As you can see, I'm feeling rather blue. When I first put the computer together I had a LAN issue which seemed to resolve itself through rolling back drivers. After that I've alternatively had periods where it's fine and then continuous problems. Yesterday, after having a couple BSOD's early in the morning, I got the system to run the entire day, till around 1:30am without a single problem while I DL'd the Rift patch. Just this morning I was playing Rift for about 3 hours without a single problem. Then I had some issue and that caused me to run Windows Memory Diagnostic (which reported no errors) and to then DL AIDA64, which seems to have sent my system into mayhem.
At this point I'm just praying it's not a mobo failure. I'm open to any suggestions you guys may have and I really appreciate the continous help and education that the enthusiasts provide on this site....There's no way I would have even gotten this far without the information provided on this site.
EDIT: Just had another headache inducing screen. Had to boot and a screen came up detailing my system and saying CMOS Checksum Bad. It gives me options to enter menus but nothing happen when I press the buttons on my keyboard. Now it's just going to that screen every time I boot.
1. STOP 0x0000001E
2. BAD POOL CALL
3. STOP 0x0000007E
