Hello everyone I have decided to build a PC instead of buying the next gen consoles. I have never done PC gaming before due to never having a computer that could handle games. I went into this build wanting to spend 500$ and would be ok with playing recent releases on medium settings.
After visiting a friend with a high end rig and watching Laura Croft's sexy *** on Ultra everything and that awesome tress effex on I just don't think medium is going to cut it for me. So here are some new goals. Run most recent titles on high/ultimate at 1080p and have some wiggle room to overclock and continue my goals for the next 2-3 years.
So here is what I got. Please be brutally honest with my choices as I am uneducated on the subject and there is only so much research I can do.
Case : http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
PSU : http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
MOBO : http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
CPU : http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
CPU Cooler: To be Determined (Coolermaster?)
GPU : http://www.newegg.com/Product/Product.aspx?Item=N82E16814127761
RAM : http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
HD : http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
I might get a smaller HD as i currently have a 300gb and have used less than 200 of it. I tend to delete most things when i done with them.
In the future I want to OC the CPU and GPU to keep up with games. Also plan on getting another 270x and larger PSU when required.
Thanks all input will be appreciated.
