Usual, long time lurker, first time poster, and finally getting a system, and ready to get in the OC / Water cooling scene!
So I ordered a slim 27.5mm 360mm rad, DDC 3.25 PWM pump / Res combo, and was planning on cooling both my OC'd CPU, as well as a mildly OC'd GPU. Will this be enough?? Here are the specs
Build:
- Asus Deluxe X99 Deluxe II
- i7 5820k
- Sapphire R9 280x Dual-X OC (upgrading soon)
- 4x8GB G.Skill RipJaw 4
- HX860i PSU
- Evolv ATX Glass Silver
Loop:
- DazMode 27.5mm 360mm Rad
- 3x Gentle Typhoon fans
- 300mm res with DDC 3.25 PWM
- HEATKILLER® GPU-X³ Core 60 DIY (GPU + VRM)
- HEATKILLER® IV CPU block
What do you guys think? Would this be enough for me to OC the CPU to 1.3V @ whatever it's stable + GPU with OC to whatever the locked voltages allow?
I'm dreaming of a 30c-35c loop, but I can't see it happening with a single rad?
Bonus question, as I am new to this, I read that once the loop gets above 40-50c I should start looking into additional cooling as it can create leaks?
Thanks!
JEB
Build:
- i7 5820k
- HX860i PSU
Loop:
Thanks!
JEB
