This is the first desktop Ive ever built and I have done some research and I think the components I have chosen will work for what I need them to do. I want to run games like SC2 on higher settings as well as run software such as Matlab. I also want this computer to last for a while so that I will not need to update it in the next 6 months to a year and still be able to handle most games and software without any problems. If you see something that would fit better than anything I picked out or that is cheaper because I am trying to stay within a budget of 700-850 please mention it. I appreciate the input in advance guys.
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
$219.99
ASUS P8P67 LE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131706
$124.99
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
$49.99
XIGMATEK ACXTNRP-PC602 600W ATX12V Ver.2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817815009
$54.95
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315
$69.99
^^^This is a concern of mine if anyone has some suggestions Id like to hear them.
TP-LINK TL-WN722N Wireless Adapter High Gain IEEE 802.11b/g/n USB 2.0 Up to 150Mbps Wireless Data Rates 64/128 bits WEP WPA/WPA2, WPA-PSK/WPA2-PSK (TKIP/AES)
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045
$19.99
Seagate SV35 Series ST3500411SV 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148728
$53.99
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
$59.99
The case is also a concern, do you guys think everything will be ok as far as fitting in here?
HP 24X Multiformat DVD Writer 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model 1260i
http://www.newegg.com/Product/Product.aspx?Item=N82E16827140042
$24.99
Also is there anything that Ive missed aside from the monitor, keyboard, and mouse? Again thanks guys this is my first build so Im trying to make sure everything is compatable.
$219.99
$124.99
$49.99
$54.95
$69.99
$19.99
$53.99
$59.99
$24.99
