I got a DICE pot in today and I plan on running my first DICE session tomorrow with an E6400. I will update the thread with how it goes with pics and results but I need some feedback on how well or not so well I put on the art eraser onto the mobo. Should I put eraser inside of the CPU socket where it holds down the CPU? Also, is it ok to put in the eraser inside of the socket where the pins are in that hollowed out square? (I have witnessed someone use a paper towel and I think vasoline should work?) What should I sit under the motherboard? I plan on using cardboard.
Also, any tips or feedback or criticism or links are welcome. I have read a little on dry ice in the sticky threads on the forums but in all honesty I am a noob. I am using a cheap board so if I destroy it somehow with condensation then I won't be upset. I will start tomorrow sometime early whenever a place with DICE opens up and will keep this thread updated. Maybe we'll get a few laughs from my screw ups =].
Pic of DICE pot (d= 2 in and h=7.5 in and I believe this pot previously was owned by someone from here but I got it off OCN): Apparently I suck at inserting pics so they are below as attachments
