I'm building an acrylic tube setup with bitspower 16od acrylic tubing and bitspower fittings. The initial fitting I chose was the BP-MBWP-C89. This appears to be a one piece fitting...i.e....it doesn't unscrew. Is this meant to have the tubing end press fit into it? If so, what is the best method for doing this so the tube enters straight and doesn't damage any o-rings? Or am I just using the wrong fitting? Any advice and instructions would be greatly appreciated.
Thanks
R
Thanks
R
