hey to everyone! I've been reading around these parts for a bit but this is my first post. After reading about others experiences I think it's time to get my feet wet. I've tried to put the parts together as best I can but need a little guidance.
New System
Asus Sabertooth 990fx R2.0 motherboard
FX-8350 cpu
<strike>16GB Corsair XMS3</strike> 8 GB Ares
EVGA 660 Superclocked 02G-P4-2662-KR
A smallish SSD for OS
(4) 7200 hdds
for cooling
either
Option 1
xspc raystorm rx360 kit with the D5 variant/combo res
adding (2) Alphacool coolplex pro res
EK GeForce 660 GTX VGA Liquid Cooling Block
<strike>Bitspower HDD Acetal Liquid Cooling Block (Hdds mounted on their sides with the block on top)</strike>
flow meter (not sure which one yet)
<strike>Memory water block?</strike>
Option 2
xspc raystorm amd block
mc9655 pump
xspc rx360 rad
yates fans
and the rest of the same from option 1
So...I am doing this more for the silence than overclocking but I as a tinkerer will never rule that out. My concern is whether or not the pump in Option 1 is sufficient to run the loop (assuming my suggested loop is a good one). I don't like to half a** things and spend unnecessary money so if im better off flow/reliability/insert good reason here to piece together the system and pay a bit more I will, even if it means buying 1 part at a time.
Another concern is well maybe I should have started out with this. I am building a desk (inspired by l3p and red harbinger), not my first pc buildi by any stretch but my first water cooled one. I more than likely will not have much if any airflow so I need/want to cool all the necessary parts. The desk will be made out wood and stained to blend in with the furniture (the only way I got the nod of approval from the boss). Everything will be on standoffs and nothing will be directly mounted to the wood. The top will be glass/plexi and I havent decided on coolant color or lighting as of right now. First build a solid system then worry about it looking pretty
I want to build the system that I can upgrade and tinker with as my knowledge grows. maybe switching out the fans for gentle typhoons, etc.
And...as if this wasnt complicated enough for me I am also contemplating using my current rig (q6700, 8gb ram, dg33tl, 9800gt) as a NAS on the other end of the desk, but I cant find any pieces to watercool that so it may not even be an option.
As you can tell I am not really a pc gamer aside from World of Tanks but I primarily run a ton of media, as my current system serves up media for my entire house and tablets/laptops when out and about.
Sorry for this being so lengthy but I wanted to get as much information to you as possible as well as a decent introduction since Its my first post.
Any and all criticisms are welcomed...I'm a big boy and if something I suggested is stupid then feel free to correct me.
New System
FX-8350 cpu
(4) 7200 hdds
for cooling
either
Option 1
Option 2
mc9655 pump
xspc rx360 rad
yates fans
