- Nov 29, 2001
- NC, USA
okay, i succsessfully upped the clock on my classic slot a 750 to 8.5.. my mother board only supports fsb up to 115 so i can run at 977 stable.. oh yeah i upped the voltage from 1.65 to 1.75 otherwise i wasn't able to get over 930 via fsb.
so here's the question. i'm sure if i raise the multiplier up to 9 then i can use the fsb to break the gigahertz mark!! but i will need to up the voltage again to at least 1.8
right now i'm running around 40 degrees under load. i need to know what kind of temp increase i should expect from another .5 voltage increase... i'm using a good heatsink dual fan and lot's of big system fans. oh yeah. doing all this without the aid of a gfd... so the least changing i can do the better. soldering gets frustrating ya know??!!
