Without changing multiplier I have been increasing FSB until 360, changed memory to 1:1 so it works now at 720.
Did nothing with voltage, set to AUTO, Ai-suite shows 1.38-1.40.
When increased FSB to 380 bad things started to happen: I saw RAID broken (???), rscreen resolution changed (???) could not even enter BIOS. When finally (10th attempt) entered BIOS, changed FSB to 360, now boots correctly.
At the moment I am running two Super PI (both 32 mln digits) 100% load, CPU speed 3240 (=9x360), memory - 720 and CPU-Z shows 4-4-4-12, althought I did not try to overclock memory at all (???), CPU temp - 41, system - 35.
Question: has system reached max and I ahould leave it at this level, should I try FSB 370, or do something more fancy? If I stay at this point, how do I test for stability?
Thanks!
EDIT: CPU temp 43 now.. is it still OK?
ASUS P5B-deluxe
E6600+Zalman CNPS9700
2GB Corsair DDR2-800
NVidia Geforce 7600 GT OC
2 x Raptor WD1500 (Raid 0)
Seasonix S-12 500W PSU
Antec P180B
Thanks!
ASUS P5B-deluxe
Antec P180B
