Are temps really that high? i was assuming they were well within actual safe parameters even though worse than actually recommended.<<<<?????
Regardless i made a few changes
- set the multiplier lower to 4ghz
- set manual voltage to 1.35
- changed the llc from auto to normal (the only other option is extreme)
- and tried running prime95 again. Temps stayed around 54 C when running 6 threads of that "torture test" after half an hour.
The readings in hwmonitor were interesting (to me) but i stupidly botched the screenshot??? i swear thats never happened to me before D: Anyways my vcore remained considerably lower, occasionally reaching 1.338v but staying in the 1.32's. i regret not being able to undervolt as you suggested. My bios wont let me go bellow 1.35. Should i try to get my desired freqs by changing fsb multi? what kind of change should i expect in my overal voltage that way? or is it the same thing.. im kind of lost.
Also, during the tests i notice my cores jumping between 4000 and 3000 very quickly. Is this a power saving feature i should turn off? or is it throttling? i'm inclined to power feature since there are fewer jumps when running 6 threads of testing than 3 threads.
Turbo?
tomorrow i will search online and make more calls for a cooler as suggested, but realistically i'm looking at one or even several months with this hardware. The other board is ready for me, on the other hand. Is it worth the switch? The sucker will charge equivalent of 40 bucks to replace my board, taking the old one. I might get him to just sell me it... idk
I will probably do some more testing when the weekend is here. Input on any of my thousand questions is welcome. night folks
