- Mar 25, 2012
Hey all -- I have stumbled across these forums many times in the past but never had much cause to be anything more than a lurker.
I am in the process of putting together my first self-built gaming PC. I am a little intimidated to be honest because the most I have really ever done inside of a PC is replace RAM -- replace a PSU -- and install GPU's.
Installing the CPU itself scares me a bit -- and also dealing with anything in BIOS or configuring HDD's/SSD's is totaly out of my realm of experience.
I have mostly all of my components picked out:
Case: CoolerMaster HAF X
PSU: ThermalTake TR2 1000w
MOBO: ASUS Sabertooth x79 LGA 2011
RAM: Mushkin Enhanced Redline 16GB (4x4) DDR3 1600 Quad Channel
CPU: i7-3930k
SSD: Intel 520 Cherryville 120GB
HDD: WD 1TB 7200 RPM Internal Enterprise
OS: Win7 64-bit OEM
GPU: Waiting on a 680 to become available
My main concern right now is my CPU cooling solution. I am looking at Intel's socket 2011 closed loop liquid CPU cooler -- but I am also looking at the new Phanteks heat sinks. I would much rather use the Phantek model but I am concerned about the size of it.
Has anybody here done a similar setup using a larger heatsink/fan like the Phantek with the 2011 socket? I am initially planning on sticking with the 4 DIMM setup with 16GB but eventually I might throw another 4 DIMMS in and even still I am guessing I will have to stagger the first four DIMMS across both sides anyway.
If anyone can offer some advice I am all ears and willing to learn -- this is my very first complete PC build and I want to make sure I am making the correct purchasing decisions.
Thanks
CPU: i7-3930k
OS: Win7 64-bit OEM
Thanks
