count_zero99uk
- Jun 24, 2018
Hi there,
I was looking around for bits to build a new pc and realised my chip is still pretty good, i7-2700k. I spoke on some forums and i was told that it was a snap to overclock and with a good GPU id be more than happy with the results.
So ive got myself a new GPU the KFA2 GEFORCE GTX 1070 EX 8192MB
And i am waiting for a GA-Z77-D3H to come through the post, 2nd hand and i hope it works.
Also will be using 16gb of DD3 1600 ram that i have from my previous machine.
Things im not sure about is cooling, cases, and psu.
Ive been looking around and think i have found some things which may work according to part picker, but im not sure how good that is.
I like this look of the SOURCE 340 MIDI-TOWER CASE - RED WINDOW but looking at the specs it only has a cpu cooler clearance of 161mm. How much leeway do you have in these, does that mean my cooler should be 160mm, or is that pushing it?
I found one cooler i liked the look of but it said the height was 163mm - thats the Cooler Master Hyper 212 LED CPU Air Cooler.
So now im looking for something that will fit the colour scheme i like red/black (fits the gpu) Any recommendations would be great.
Finaly im still confused over a psu I keep getting conflicting information, i know to get one from a good brand, but its how much power i need. The GPU recommends 500w but do i need more power if im overclocking?
I do hope you can help
Many thanks
Brian.
Many thanks
Brian.
