Hi guys. New around here. I also got my hands on a R5 1600 AF and i want to mix it with ID-Cooling SE-234-ARGB + ADATA XPG D41, 8GB DDR4, 3000 MHz, CL16 X2 but the motherboard is still in pending but i will try to get ASUS TUF B450M-PRO GAMING for it because here in my country the AM4 MB are very low in stocks. I never did an overclock to anything that i owned. But with this one i want to do a safe one if possible. I don`t want to win an award or something but i want to raise it a bit. Can i get a few pointers? On how can i start safe or the simplest method to bump it up.
P.S I might get a ASRock B450 Pro4 if the first one does not arrive in a timely manner.
I`ve read about Ryzen Master a bit and about the memory side of overclocking with the use of Thaiphoon Burner + DRAM Calculator
With those i can do a rather easy overclock? There is a difference from using Ryzen Master vs doing them via BIOS?
Like i said i`m not looking for first place award.
Also from what i have read over the forums the voltages must be below 1.4
Thanks in advance.
Thanks in advance.
