- Apr 25, 2005
- Fredericksburg, VA
Hey guys, I've been reading around a bit on watercooling since it caught my interest a while ago, and am working on making a new computer at the end of the summer or so and am planning to watercool it.
System specs:
CPU -> AMD A64 3500+ Venice Core @2.2Ghz
GPU -> ATI Radeon X800XL (Unless somebody can convince me NVIDIA is better, I like my ATI's so far)
Case -> Looking at getting a modded Chenbro Genie , the mod being the 2 120mm fan holes in the front. Any thoughts?
I've pieced together this so far:
Rad -> Black Ice Extreme II
Res -> 5 1/4" Bay
Pump -> Swiftech MCP350 (Is there a difference between this and the DD pump?)
CPU Block -> Swiftech MCW6000-64
OR
DD TDX block
GPU Block -> DD Maze-4-1 GPU block
Few questions about it:
-First, is there any difference between the Swiftech pump and the DD pump? The pics and specs all look very similar, for about the same price.
-Which is the better waterblock? The Swiftech is cheaper, though kind of bland looking (looks aren't everything though, I want functionality). I've also heard that the lucite tops for waterblocks can be a bit weaker, and while they look cool, will give out eventually.
-Is there an advantage to having a 3 barb block instead of 2?
And finally the fan questions:
-For the radiator fans: 2 or 4? I've heard some people say to have a fan on each side of the radiator, one to push and one to pull... is there any real advantage to this?
-Is there an easy way to control all the fans? I would like to be able to turn the fans down when the comp isn't in use, unless i'm mistaken in thinking that 4x120mm fans will get a bit loud.
-3-pin fan plugs or 4-pin? I don't see any 3-pin on my PSU, so i'm wondering what the practicality of having a 3-pin is? MoBo plugs?
Hope you guys can help ^_^
System specs:
Res -> 5 1/4" Bay
OR
DD TDX block
