- Oct 14, 2008
So I set EK Water Blocks EK-XRES 140 Revo D5 PWM and used some anti vibration rings on the bottom and at the back of the mount to hopefully cut down on vibration, the only problem is it wobbles quite a bit when the case is moved or possibly knocked by accident. it seems very sturdy apart from the wobble though and it's not as if it will end up on the floor. I also have the newer d5 mount/insert installed, i think this is known to create some wobble
What you guys think.... will this degrade the pump at all. Forgive the bad camera operator and the orange in the case, that will be going soon.
Also, about flushing the rads, can I just put some hot boiled water in and give it the shaky dance a couple times, then once finally with some distilled water, should that be enough. Should I also do the same for the GPU and CPU blocks as well as the tubing or is that overkill and unneeded?
