doorknob12349
- Feb 22, 2016
Hey Everyone First time posting, First Water Cooled PC!
This is going to be my new big rig mostly for gaming with some work and MSCS self study (a few VMs here and there). i all ready have all the components, i got some inside deals on a few and saved up here and there. I'm at my lest set of parts which is all of the Water cooling gear. if i could get some impute before i purchased the parts the would be great.
Dose anyone know if a PWM splitter will work on the Corsair commander mini?
The Corsair 900D has all of the Coldzero plates including the Mid plate. My plan for the loop was to mount the Reservoir off to the right of the Motherboard, then go into the pump mounted on the mid plate into the Bottom 480 Radiator, come back up into the Dual GPU, next into the CPU, onto the top mounted 360 cross-flow Radiator, back into the reservoir. i'm unsure where to put a drain port or what i would need for that, i have removed all drive carriages bellow so there is room below in front of the PSU.
Loop Plan (Ignore the Yellow Circle)
Case with coldzero parts (ignore the yellow Circle)
Computer Specs:
Water Cool Components
Thanks!
Computer Specs:
- Case: Corsair 900D with Coldzero Plates
- PSU: Corsair AIX1200I
- Motherboard: Asus x99-E WS USB3.1
- CPU: Intel i7-5930k
- Memory: Corsair Dominator Platinum 64GB 8x8
- GPU: EVGA Nvidia GTX 980ti 06G-P4-4995-KR 6GB W/Back-plate
- SSD: Samsung E 512GB 950PRO M.2
- 2nd SSD: SAmsung 512GB 950 Pro Sata
- Fan controller: Corsair Commander min
- PWM Splitter: SilverStone All Black 1-to-8 PWM Fan Hub (CPF04)
- Radiator 1: XSPC EX360 CROSSFLOW SERIES COPPER TRIPLE-FAN RADIATOR
- Radiator 2: XSPC EX480 COPPER QUAD-FAN RADIATOR - BLACK
- Reservoir: EK-RES X3 250 RESERVOIR
- CPU BLock: EK-SUPREMACY EVO NICKEL/PLEXI
- GPU Blocks: EK-FC TITAN X/GTX980 TI WATERBLOCK - NICKEL
- GPU SLI Bridge: EK-FC BRIDGE DUAL SERIAL CSQ - PLEXI
- Pump: EK-XTOP DDC 3.2 PWM ELITE - PLEXI
- Fittings: RIGID REVOLVER COMPRESSION FITTING 3/8" X 1/2" 10 PACK - DUAL TONE ANODIZED BLACK
- Tubing: PRIMOCHILL 1/2IN RIGID PETG TUBING - 36IN - CLEAR (12 PACK)
- Coolant: MAYHEMS PASTEL COOLANT - 1 LITER - PERFECT PINK
- Fans: CORSAIR AIR SERIES SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN
Thanks!
