Hello everyone, I've been following this forum for some time but just now posting.
My current rig does distributed computing while I'm not using it (and sometimes while I am). This makes a fair amount of fan noise and the video card runs pretty much around 80 degrees C. I primarily want to get the temps on the card down and then make the rig as silent as possible.
So this is what I have now:
Asus Z87 Pro MB
4770k
EVGA Titan superclocked
Not currently overclocked. I've had it 4.4 stable. I brought it back down to stock because it runs HOT when AVX gets involved, as I'm sure any primegridders on here can attest to. I wasn't comfortable going over 3.7 when those were running. If this works well I may have to revisit it.
It's currently in an Antec 900 which I will be setting aside for my next project.
I got a deal on a Corsair 900D so that's what I plan on moving everything into.
What I'm looking at is:
XSPC RX480V3 (mounted on top)
Alphacool Monsta full copper (mounted on bottom)
XSPC GTX Razor V2 Full coverage water block and back plate
Koolance 380I CPU cooler
Noctua NF-12 fans for the rads (push/pull on both)
Tygon Norprene 3/8 ID, 5/8 OD tubing
Assorted Bitspower barbs and clamps
XSPC Laing DDC Reservoir Pump attachment w/MCP 350
The order I was looking at is:
pump/res -> Monsta -> Titan -> rx480 -> 380I -> pump/res
After reading and reading and reading various posts in here and elsewhere I have a couple of questions.
Would the 350 with the restop be sufficient or should I go with a 355 (seen a lot of posts suggesting the 350 would be fine, but some (including the Beginner's Guide here) suggested a 355 as I have 2 rads. Or should I go all the way to a 655?
The other question concerns the EK Supremacy block. There still seems to be a bit of a war going on over these so I was wondering if anyone here had recent experience with it. For a haswell it apparently has the best performance but if EK parts are still suspect I'll stick with the 380I.
The NB has a nice heatsink on it, and I assume the fans on the top rad will draw air across it so it should be good to leave as is. Should allow me to mount the fans that came with my ram though I'm not sure if they're worth it.
Any critiques/suggestions would be appreciated. Particularly for a fan controller as I'm having trouble narrowing down what I want to use.
I know I've over-radding it but I'm hoping that will help keep it silent/nearly silent.
Much appreciated.
Asus Z87 Pro MB
4770k
Much appreciated.
