- Oct 13, 2004
Hi guys,
Looking at getting the Corsair Carbide Series Air 540 case which I want to throw some water cooling into it.
It supports a 280mm radiator at the top and 360mm radiator at the front....What should I consider?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139029
Since this is my first time, should I get an integrated res and radiator?
What about the pump?
This is my goal:
I want a high quality system that will last years.
I want it to be easily upgradeable if I switch CPU's and sockets etc.
CPU ONLY right now. BUT I want to be able to put the GPU later.
What recommendations can you guys give here?
This is my goal:
