Thank you that is one of the ones i was looking at but was unsure if it could handle the load.
Slightly updated shopping list:
a. Res : EK-RES X3 250 Reservoir
b. Pump : Swiftech MCP655 Special Edition 12 VDC Pump With Speed Controller
c. Cpu block: Koolance CPU-380I Water Block (Intel Processor)
d. Rads
i. Swiftech "eXtreme Performance" Triple 120mm Radiator
ii. Swiftech "eXtreme Performance" Single 120mm Radiator
iii. Alphacool NexXxoS Monsta 240 Radiator
e. Fans
i. 8 fans Scythe Gentle Typhoon 120 mm by Nidec Servo Corp. - 1000-5400 PWM Fan - Sleeved
ii. 2 Akasa Viper S-Flow 120mm fan(case fans)
iii. Swiftech 8-Way PWM Splitter Box
f. Fittings
i. Bitspower Ultimate G 1/4 Thread 1/2" ID x 3/4" OD Compression Fitting - Silver Shining (BP-CPF-CC5)
ii. Bitspower G1/4" Silver Shining Dual Rotary 45-Degree Compression Fitting CC5 For ID 1/2" OD 3/4" Tube (BP-45R2CPF-CC5)
iii. Bitspower G1/4 Thread 90-Degree Rotary 1/2" ID x 3/4" OD Compression Fitting (BP-90R3CPF-CC5)
iv. Bitspower Deep Blood Red Y-Block Fitting With Triple G1/4" Ports (drain line)
g. Tubing
i. Masterkleer PVC Tubing 1/2" ID / 3/4" OD - 10ft Retail Pack - UV Pink
ii. Masterkleer PVC Tubing 1/2" ID / 3/4" OD - 10ft Retail Pack - UV Purple
h. Misc
i. IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
ii. Phobya HeGrease Extreme Thermal Paste - 3.5g
iii. Koolance Threaded Rubber Funnel - G1/4" Thread (LIQ-FNL)
Which is better a pump/res combo or 2 separate pieces?
Also Swiftech "eXtreme Performance" 240 vs Alphacool NexXxoS Monsta 240 Radiator the alphacool should yield greater benefit because it is 80mm thick correct?
Also the tubing is confusing me now it appears to be the same tubing but frozencpu lists it at 3/4 inch outer diameter and performancepc lists it at 5/8 od and i can't seam to figure out which is right.(solved)
