pranavrules
- Aug 10, 2014
Hi All,
My first post here on this forum. I am an avid gamer and have been playing for a long time. I have always been up to date with my components, and my upgrade is coming up pretty soon. Right now my specs look a little like this:
I am upgrading to 2 780 Ti in SLi, ASUS Rampage Formula VII, Core i7 4960K and 32 GB of DDR3 RAM within the next couple of months. I am planning to water cool the entire build (each component, including the RAM, Southbridge and Northbridge of the Motherboard and GPUs). Since I've never done any water cooling before, or never have seen it in person, I have no experience with that process and honestly, I am extremely intimidated by it.
I thought it would be better if I practiced with a simple, cheap water cooling build on my existing machine before working on the new build to gain some experience and understanding of how this process works. I read through all the guides I could to understand the basic understanding of how the loop is supposed to work, the radiators, reservoirs, pumps and water blocks. Trust me, I read a LOT, yet this topic scares the bejesus out of me.
Here's a list of components that I have selected so far for the existing build that I have (listed above - Corsair 650D):
Right now, as I type this my legs are twitching with excitement and anxiety of going through with this. I don't want to mess anything up and none of my friends have ever worked with water-cooling either, so I don't know where to look for advice.. I hope you folks can help me out?
I still have to get the compression fittings, but I was looking for suggestions for which ones I should go for..
Also, I would love it and really REALLY appreciate it if someone could tell me if the above parts are compatible?
Thanks,
P
- Case: Corsair 650D
- Motherboard: MSI Z77A-GD65
- CPU: Core i7 3770k OC'd at 4.2 GHz
- CPU Cooler: Corsair H100i
- GPU: 2 EVGA GTX 670 in SLi OC'd at 1000 MHz
- RAM: 16 GB Corsair Dominator DDR3 1500
- PSU: SeaSonic Gold 850 W 100% Modular
- CPU Block: EK Supreme LTX Intel CPU Liquid Cooling Block - Nickel CSQ (EK-Supreme LTX - Nickel CSQ)
- GPU Block: EK GeForce 670 GTX DCII VGA Liquid Cooling Block - Nickel CSQ (EK-FC670 GTX DCII - Nickel)
- GPU Backplate: EK GeForce 670 DCII GTX VGA Liquid Cooling RAM Backplate - Black CSQ (EK-FC670 GTX DCII Backplate - Black)
- SLI Bridge: EK FC Bridge Dual Serial 3-Slot CSQ - SLI Connection - Acrylic (EK-FC Bridge DUAL Serial 3-Slot CSQ Plexi)
- Pump Reservoir Combo: EK Dual 5.25" Bay Reservoir / Pump Combo - w/ D5 Vario (EK-BAY RES D5 Vario (incl. pump))
- Top Radiator: Magicool Extreme Dual 120mm Radiator - Slim Profile (LC-RADI240)
- Back 120mm Radiator: EK High Performance CoolStream 120 PE Series Liquid Cooling Radiator (EK-CoolStream PE 120 (Single))
- Front 200mm Radiator: Phobya Xtreme 200 Radiator - 60mm Version 2 - Full Copper
- Tubing: PrimoChill PrimoFlex Advanced LRT Tubing 3/8"ID x 5/8" OD - 10ft Retail Pack - Red
[*]Dye: Mayhems Aurora 2 Coolant Concentrate - 250mL - Tharsis RedAs suggested by caddi daddi, going with red tubing instead - Jump Start Connector: FrozenCPU 24-pin Power Supply Jump Start Connector
- Silver Coil: IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
- Distilled Water: PrimoChill Base Intensified™ - High Purity Deionized Water - 1 Gallon - Clear (PC-BASE128)
- Top Radiator and Back Radiator Fans: Corsair Air Series SP120 High Performance Edition High Static Pressure 120mm Fan (CO-9050007-WW)
- Top Radiator Gasket: XSPC 2 x 120mm Radiator Gasket - 3mm
- Front 200mm Radiator Fan: BitFenix Spectre All Black 200mm Fan (BFF-SCF-20020KK-RP)
- CPU Thermal Paste: Tuniq TX-4 High Performance Thermal Grease - 3.0g
Thanks,
P
