I have recently purchased a graphics card I have decided to switch to water cooling so I can get better overclocking and lower temperatures . I have just finished most of my water cooling research and have came up with a candidate for my first possible water cooling system . I would greatly appreciate any feedback on the following plan.
My current plan is to cool one gtx680 and i7-2600k in a single loop with the following:
CPU Block : EK Supremacy
GPU Block : EVGA GTX680 Hydrocopper Block
Pump : Swiftech MCP35X & Swiftech MCP35x heatsink
Reservoir: Swiftech MCP35X Reservior
Radiator : Aquacomputer airplex Revolution 360/420
Fans: 3 x 120mm Gentle Typhoon 5400 rpm for radiator and 1 80x15mm Yate Loon fan for pump heatsink
Tubing & Fluid : Tygon tubing ( size undecided ) , appropriate fluid with biocide (exact specifications not decided)
Main concerns & Questions :
Will the components be compatible , and is this a reasonable build ?
I plan to put this in my NZXT Phantom (222 x 540 x 623) , not sure if everything will fit , even after removing the hard drive bays .
I was originally deciding to use an alphacool d5 vario pump with EK D5 X acetal pump top inside a xspc dual 5.25 bay reservior ; only reason I didn't choose it is because not sure if you can actually do such a thing , is this possible?
I might be paranoid but just to confirm the following -
Anodized aluminum from the pump heatsink will not affect my copper setup because since it never hits water and is thus actually out of the loop .
3 radiator fans at 5400 rpm while sounding horrible will give me significantly better cooling than 3 3000 rpm or lower fans , and i can hook up the radiator fans to the nzxt phantom fan controller
Would you recommend a silver kill coil and or biocide for this setup or are most coolant fluids sufficient?
