QuietIce
Disabled
- May 7, 2006
- Anywhere but there
Yes - and no.... and does the volume that the pump can circulate (lph) make a difference in temps?
Up to about 1 GPM the pump flow makes a big difference. Between 1-1.5 GPM there are differences but they get smaller as the flow gets larger. Once you're over ~1.5 GPM there is very little difference.
Note: Those GPMs are for a full loop, not the unrestricted pump flow that a quick spec sheet will give you ...
