Ok so heres my thought, i have an intel e8400 OC'd to right at 4.0ghz, and an EVGA gtx 295 that i want to include in 1 loop. I want to use 2 120 radiators, in my antec 900, i have one secured to the outside of the case just behind the exhaust 120, i want to make a custom bracket to put another 120 rad./fan combo just under the 200MM fan blowing out the top of the case.
so heres my question, im thinkin to cool the hot gtx 295 and my cpu without passing heat from one to the other im gonna have to go from res. to gpu waterblock to rad. to cpu water block to rad then back to res. right?
and also i was considering buying one of the res./pump combos that fit in one 5.25" bay, are these usually adequate for the loop i want to build?
and if so what kind of pump and res. should i be looking for?
Thanx in advance,
Thanx in advance,
