Nice. Isn't the secondary PCIE slot make the card run in 8x mode instead of 16x?
Looking at the pics from the OCF review (link) it would run in x8.
Dino said:The PCI-E expansion slot area shows we have three PCI-E 2.0 x1 slots, two PCI-E 3.0 x16 slots, and one PCI-E 2.0 x16 slot. A single video card can operate at x16 speed, and a two card SLI/Crossfire setup will run at x8/x8 speeds.
I must not be seeing what pics you're referring too. Here's what I'm looking at.
Where is is saying that slot 2 will run at x8?
Those sneaky sons-a-....
Very good catch Mr. INSIDE.
Well, it's not like the OP has much choice in the matter. It doesn't look like that Res/Pump will fit anywhere that wont interfere with slot 1.
I figured the secondary PCIE slot would run the card in 8X mode. A sacrifice had to be made in order to shove that 140mm res in that tiny space.
Wondering if the OP's gaming performance is neutered?
That is just stating the slots are physically x16 length. Look at the back of the motherboard and you'll see they're only soldered to x8 for slots 4 and 6.
Picture title is "Naked Motherboard – Bottom Side" that I'm referring to.
Very typical for all motherboard manufacturers.
Likely 1-2% or less.
It can clock a lot higher, though. I've gotten 3409 in Heaven with a LE BIOS and a hammer. LOL
You're fine at PCIe x8. You'd only see the difference if you wanted to count for every FPS say if you were running 1080p, 1440p or 4K in triple screen surround. That's where it's utilized the most, otherwise you're good to go.
Btw, well done on your rig. You worked with what you got and it came out nice.
And I was remiss in not echoing this sentiment. That's a very nice, and nice looking, rig you built.
