Hi, I currently own a Gigabyte Eagle RTX 3090 which is power limited to 350W. The card will happily run at 1800mhz up from 1650mhz stock, however it keeps throttling back down to ~1725mhz due to its max power limit. Thermals are in check.
I know that Gigabyte also released a similar GFX called the Gigabyte Vision which uses the same 2x8pin power supply but this card has a power limit of 390W. So my question is, has anybody any experience flashing cards from the same manufacturer? … is it as straight forward as it sounds or am I likely to brick my card :/
Thanks,
Thanks,
