I had 8600K which was overclocking below average and I was changing the whole build. Idea was to buy a bit stronger CPU which I could overclock keeping stock voltage or lower. There is a higher chance to get good overclocking 8086K than 8700K ... and I just wanted 8086K even though I know it's a waste of money.
I was testing many ITX cases and I can tell you that every cube case will let to keep lower noise than anything "flat". That Kolink case is still good option as whole alu exterior works as a heatsink (it's pretty hot when all is under full load).
Flat/slim silverstone cases will need the same coolers as Kolink but in total take more space.
You can also take a look at this brand. Full alu, should be option without window but for some reason can't see it. Prices are quite low and quality is good:
https://www.raijintek.com/en/products_detail.php?ProductID=17
This cooler fits into most "flat" cases but you have to check height from CPU to side/top panel:
https://noctua.at/en/products/cpu-cooler-retail/nh-l12s
For that will be required low/standard height memory.
I'm using this one:
http://www.cryorig.com/c7cu.php
with G.Skill Trident Z RGB ( like I care about RGB in a closed case without windows )
I'm using this one:
