- May 28, 2002
- Sector 7G
Around 150-300
FDUSMC said:I reduced the length of my hose by about 4 feet and so no change in temp whatsoever.
the pipes carrying cold coolant FROM the radiator TO the heat exchange device - if insulated - will help to maintain the low temperature of the coolant
johnny007 said:
It isn't a closed system, there are too many variables.
johnny007 said:I think the emphasis on flow rate is somewhat less important than many seem to be implying...The critical cooling system devices are the heat transfer efficiency of the interface between the heat source and the coolant and of course the efficiency of the heat dissipation unit.
johnny007 said:The key is that the temperature differential between the heat source and the coolant be as high as possible and the heat transfer between them as efficient as possible
johnny007 said:Insulated pipes on the cool side of the system may have a significant effect also.
johnny007 said:It is a shame there aren't mechano type heat sinks and plumbing pieces to attach to devices and construct a complete customised pipe network from preformed sections, hmmm i wonder....
OK a little less pedantics wouldn't hurt. The only true closed system is the universe. It has nothing to do with mass and everything to do with energy. Energy in the form of matter maybe. A closed system is completely independent of it's environment, are you saying a water cooled system inside a PC is that?garasaki said:
Um, the definition of closed system is a system that does not allow mass transfer across its boundary. Most WC systems fit that description and are closed systems. It has NOTHING to do with the number of variables involved.
Pedantics again, I said flow rate is not as critical as some are suggesting. If you've got the bit between you're teeth and aren't going to let go then the discussion is over.garasaki said:
You're contridicting yourself here. Heat transfer efficiency is influenced greatly by flow rate. If you never have, it would be a good idea for you to go pick up a heat transfer book at your local library and read up on convection...
I never disputed the fact that a flow rate is important, I said it wasn't as critical as some are making out. The thermodynamic properties of the coolant and the design of the devices doing the cooling are much more critical.garasaki said:
You're certainly right about both these points, but you should note that the heat transfer is affected by flow rate. Therefore, the arguement about the optimum flow rate is indeed important!
No heat escapes from the tubing. On the cool side the heat of the pipe wall from the ambient air temperature is being drawn in and will have a slighty detremental effect on the coolant temperature, it may well be very small. Insulation was just a suggestion. If the cooling efficiency of the system were too great then condensation would be a huge problem. The pipes and heatsinks would require insulating on all exposed surfaces.garasaki said:
I don't personally believe that to be true. How much heat do you really think escapes the tubing, which is made of plastic (an insulator) and is of relatively short length. The main reason you see insulation on pipes in buildings (wether they be plumbing or HVAC related) is to eliminate condensation, NOT to keep the material inside at a certain temperature. Water in the walls of a building is a very bad thing.
johnny007 said:The thermodynamic properties of the coolant itself are critical, the design of the heat sink is also. It will determine the uptake of heat into the coolant largely by maximising the surface area of the coolant channels within the heatsink.
