BillA said:err, I believe I said higher temps with less flow, no ?
(exacerbated by pump throttling)
the various graphs around showing flow rate vs. temp are all mine, it seems that no one else (that posts) has the equipment necessary to generate good data
and though it be ever so slight at much higher rates (say 3 to 5 gpm), more flow always results in lower die temps
- when the flow rate is the only variable
but since WCing systems are an interactive set of components, it is not difficult to encounter situations where the substitution of a 'larger' pump did not increase the maximum overclock
much of this difficulty relates to the pump selection process, it is not performance driven - its cost driven
(high volume pumps are being used where a higher head pump would be more appropriate)
there is, for example, an Iwaki pump to fit EVERY circumstance; but even a high-roller like myself won't pay their prices - cost again
(but eBay is a great resource, got a new Iwaki 0.6gpm 45psi mag drive gear pump for $25 - $650 list)
I continue to believe that the expenditure of additional effort in the pump selection process is worthwhile
one cannot reduce the heat load from the CPU, but that from the pump is another matter
be cool
army_man said:hey why couldnt have brotten this topic up a few months ago before i took my test on thermodynamics. my physics teach is a ***** and readying ur article made more sense to me than learning from that *****. thanks.
dont ya just love physics
RhoXS said:
Actually it would probably be best if your English teacher also had the same personality as your Physics instructor.
If you really want to learn this stuff at a reasonable level apply for a job as an Operator at your local Nuclear Power Plant. They will teach you from scratch everything you need to know about Thermo without using a single differential equation. They even start with basic Algebra and Physics. You will spend well over a year in class, at a good wage with reasonable benefits, before you do one ounce of usefull work. The public typically has no idea how well trained these operators are. Unfortunately, they will not help with the English problem.
RhoXS said:Owenator, Salem or Hope Creek? I am in Ops training (SRO Cert) at Turkey Point but my education is BSEE. By any chance do I know you? Your last name the same of one of our not to distant past Presidents? Please say hello for me to your licensing manager GS. He is an old friend of mine that I have been very negligent in keeping in touch with. If you tell him I am his old car pool buddy from Ivanhoe he will know who I am and my office number. Give me a call.
baker269 said:So since flow rate is king you would benefit more from running duel rads in series rather then in parallel?
fan freak said:decreasing the hose length does most definetely not alter the flow rate.
after all the flow rate is determined solely by the pump.
the reason the temperatures increased is because the volume of water decreased.
