- Jun 4, 2002
- salinas,ca
BillA -
I didn't write the stfu comment.
I don't think we disagree - the Serck is indeed "huge" as you put it. My only point this entire time has been that I think your methodology overstated the value of coolant flow. You last wrote you thought the effect was +/- 10%. I argue that the numbers that support that point are an artifact of the 1000 watts you had available. Had the heat been capped at 200 watts, the +/- 10% would have been +/- 1%.
Again, I want to repeat I think that both your article and Hoot's were first rate. Thanks for taking the time to put them together.
Garasaki -
The last 9 readings for the three hose lengths were:
32" - 32,32,33 Seconds
68" - 38,39,40 Seconds
100" - 44,44,43 Seconds
The 68" readings showed more variability because they were the last 3 readings and I wasn't being quite as careful with them as I had been with the initial 6 readings I recorded.
Garasaki -
I dinked around with my experiment until I was getting readings that were within a second of each other. The tubing was full when I started the timing so the bucket-pitcher distance was immaterial other than as a source of friction.I'm not disputing your point here, but I'm not sure your test really proved too much. Depending on how fast the water was flowing, and when you started timing, the difference could be (nearly) explained by the fact that the water took more time to flow from the bucket to the pitcher, initially.
