- Oct 14, 2003
- Philadelphia
https://www.comcast.com/wirelessrouter/default.cspx?403;https://www.comcast.com:80/wirelessrouter/
No rental, and if you lease one now you can keep the old one and get the free one. IF you cancel you have to give it up though.
Product Features and Technical Details
Product Features
* Built-in Ultra Fast 4-port Gigabit switch means even faster network performance
* Automatic Quality of Service (QoS) ensures reliable Internet, voice, video, and gaming applications
* Surf, email, stream HD video, on-line game, make Internet phone calls¿simultaneously
* Easy secured set-up with Push `N¿ Connect using WiFi Protected Set-up (WPS)
* Maximum performance requires use of Wireless-N adapters
Technical Details
* Model Number: WNR3500
* Network standards: IEEE 802.11n draft specification, IEEE 802.11g, IEEE 802.11b, 2.4 GHz
* Security: Double firewallL Network Address Translation (NAT), Stateful packet inspection (SPI); Denial-of-service (DoS); Intrusion detection and prevention (IDS); WiFi Protected Access (WPA2-PSK, WPA-PSK); Wired Equivalent Privacy (WEP) 64-bit, 128-bit encryption for IEEE 802.11b and IEEE 802.11g; supports 2 VPN pass-through tunnels; wireless access control to identify authorized wireless network devices; MAC address authentication Exposed host (DMZ) for secure gaming
* Privacy and parental control: Time-based usage controls Web site logging URL content filtering
* Power supply: 12-volt power adapter, 1.5 A
* System requirements: Broadband (cable, DSL) router or gateway with built-in DHCP server; 5 GHz Draft 802.11n and/or 5.0 GHz 802.11a wireless adapter, alternatively, an Ethernet adapter and cable for each computer; Microsoft Windows Vista/XP/2000, Mac OS, UNIX, or Linux; Internet Explorer 5.0
* Dimensions: 1.5 x 8.9 x 6.8 inches / 39.0 x 225.5 x 172.0 millimeters (W x H x D)
* Weight: 1.2 pounds / 0.56 kilograms
* Warranty: 1-year limited warranty
* What's in the Box: WNR3500 RangeMax Premium Wireless-N Gigabit Router, stand, Ethernet cable, setup CD, power adapter, warranty/support information card
Product Features
Technical Details
