is this good build and deal?
sin4life
i dont know much about hardware, nor how to put one together.
found a webpage that builds them and has a memorial day special going on.
I want this pc to be able to handle bf4
skyrim online
and ffreborn online on max settings with no lag
looking to spend under 2k
Is this a good PC and good deal?
http://www.cyberpowerpc.com/system/CyberPower_Black_Pearl/
upgraded with these specs
Case: Thermaltake Level 10GT Full Tower Wide Body Gaming Case w/ Side-Panel Window (Black Color)
Laser Engraving: Custom Message - Max 35 characters (including spaces) (Courier New)
Internal USB Extension Module: None
Neon Light Upgrade: None
Extra Case Fan Upgrade: Default case fans
Noise Reduction Technology: None
CPU: Intel® Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
Freebies: FREE 500GB External Hard Drive with Intel® Core™ i7 or Intel® Core™ i5 based PCs
Performance Tuning Protection Plan by Intel: None
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: * (4-Way SLI/CrossFireX Support) GIGABYTE X79-UP4 Intel X79 Chipset Quad Channel DDR3 ATX Mainboard w/ Ultra Durable 5, 7.1 HD Audio, GbLAN, 4 Gen3 PCIe x16, 2 PCIe x1 & 1 PCI
Memory: 16GB (4GBx4) DDR3/2133MHz Quad Channel Memory (G.SKILL Ripjaws X)
Video Card: NVIDIA GeForce GTX 660 2GB 16X PCIe 3.0 Video Card (Major Brand Powered by NVIDIA)
Freebies: FREE $75 Value In-Game Hawken, Planetside 2 and World of Tanks w/ NVIDIA GTX 650, GTX 650 Ti
Video Card 2: NVIDIA GeForce GTX 660 2GB 16X PCIe 3.0 Video Card (Major Brand Powered by NVIDIA)
Freebies: FREE $150 Value In-Game Hawken, Planetside 2 and World of Tanks (2 x $75 Value In-Game) w/ NVIDIA GTX 650 or above SLI
Video Card 3: None
Power Supply Upgrade: 800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
Hard Drive: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
External Optical Drive: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
LCD Monitor: None
2nd Monitor: None
3rd Monitor: None
Speakers: 600Watts PMPO Subwoofer Stereo Speakers
Network: Onboard Gigabit LAN Network
Keyboard: AZZA Multimedia USB Gaming Keyboard
Mouse: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge, and more(1)
Mouse Pad: None
Headset: Cooler Master Storm Sonuz Gaming Headset w/ Flexible Headband & Detachable Microphone
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: None
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Bluetooth: None
Flash Media Reader/Writer: None
Video Camera: None
Tablet: None
Cable: None
Power Protection: None
IEEE1394 Card: None
Internal USB Port: Built-in USB 2.0 Ports
USB Port: None
Operating System: Microsoft® Windows 8 (64-bit Edition)
Media Center Remote Control & TV Tuner: None
Office Suite: None
Games: None
Ultra Care Option: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation
Service: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
Rush Service: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
You could build yourself a much better PC than this one.
First the GPUs, SLI 660 ( non ti ) is OK but you are already at the end of the upgrade path with this setup, cant upgrade without selling both 660's and getting better cards.
Then the CPU, if you are a gamer a 3570k is a much better pick with a good Z77 board.
The RAM : 16gb is a bit too much, even more with the current Ram pricing ... 8gb is a better bang/buck ( gaming wise )
PSU : No mane 800w 80+ unit ? Much better to pick yourself a well know good PSU.
Overall, build yourself your own PC. Save alot of money and have something much more suited for your needs. At ~1500$ you could beat this thing ... EZ !
can u offer a better spec from the site for me to look at.
3570k ~225$
Asrock Xtrem4 ~140$
2x4gb 1600mhz ram ~60$
GTX660ti 2gb ~250 to 300$ or AMD 7870/7950
Corsair GS600 ~100$
Case of your choice ~100$
DVD drive ~20$
At least 128gb SSD for OS ~125$
** or 256gb SSD for more space ~200$ **
1TB/2TB/3TB HDD for storage ~90 to 150$
Windows 7 pro x64 ~140$ ( you seems to want a windows ? )
Thats about it. 1300 to 1500$
Add some goodies if you want. Wait for incomming haswell Z87 proc/chipset if you can. And/or also wait for incoming GTX7xx series.
3570k ~225$
Asrock Xtrem4 ~140$
Corsair GS600 ~100$
DVD drive ~20$
So the
(3-Way SLI/CrossFireX Support) ASRock X79 Extreme 4 Intel X79 Chipset Quad Channel DDR3 ATX w/ XFast LAN, Charger, & USB Technology, 7.1 HD Audio, GbLAN, 3 Gen3 PCIe X16, 2 PCIe X1 & 2 PCI (All Venom OC Certified)
is better then the
(4-Way SLI/CrossFireX Support) GIGABYTE X79-UP4 Intel X79 Chipset Quad Channel DDR3 ATX Mainboard w/ Ultra Durable 5, 7.1 HD Audio, GbLAN, 4 Gen3 PCIe x16, 2 PCIe x1 & 1 PCI (Extreme OC Certified) [-18]
there about same price on site atm.
Also are the duel 660 2gb (or 660ti) 2gb better then the single radeon?
also whats the 3570k mean?
Lol im literally hardware retarded no lie >__<
<--- simple photographer who loves to play games lol
With a 3570k you will need a Z77 xtrem4.
Comparison
Nvidia 660 ~=~ AMD 7850
Nvidia 660ti ~=~ AMD 7870
Nvidia 670 ~=~ AMD 7950
But AMD price theire card lower so it is often cheaper to go the AMD road. but AMD currently have some issue with CFX drivers so this is not the best route to go for multiple GPU's.
If you game at 1080p ( single 1920x1080 ), a single 660ti/670 or 7870/7950/7970 is enough to max ( or nearby ) pretty much any current games.
The 3570k is a processor .... I think you have ALOT, i mean a real damn lot, of reading to do before buying yourself your own PC. Read reviews, ALOT of reviews. Then read AGAIN, alot of reviews from ALOT of dirrerent web site.
Sin4life I don't think you're going to get a good deal buying one of these prebuilt PCs. You're much better off putting one together yourself. It's extremely straightforward to do. You just need a screwdriver. That's it.
People on this forum really recommend ASRock motherboards a lot. I personally use ASUS all the time. Everybody has preferences. Gigabyte and MSI make nice motherboards too.
If you really want good performance I'd recommend going a little higher spec on the video card than others have. My suggestion would be
3570K CPU
Hyper 212 CPU cooler
Z77 motherboard of your choice
7970 or GTX 680
Corsair CX500 or 600 power supply
The cpu cooler is so you can overclock your CPU. You can push it to 4.5Ghz easily and get a nice little performance boost. The cooler is only about 30 bucks.
Pre build pc are generally more expensive then the one you build yourself, because those company that build custom pc need to make money.
Here're the link to parts that you will need to build yourself a solid gaming pc that will last you 3 to 4 year
Intel core i7 3770k
http://www.amazon.com/gp/offer-list...w?ie=UTF8&condition=new&qid=1369599806&sr=8-1
Noctua NH-D14 CPU cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
GIGABYTE GA-Z77X-D3H
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128546
SAPPHIRE Vapor-X Radeon HD 7950 + free 4 game
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202003
Samsung 840 pro ssd 128gb(make your pc run much smoother and faster)
http://www.amazon.com/Samsung-Elect...TF8&qid=1369600134&sr=1-7&keywords=128+gb+ssd
Seagate Barracuda 2 TB HDD
http://www.amazon.com/Seagate-Barra...600300&sr=1-1&keywords=seagate+2tb+hard+drive
Corsair 8gb ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233335
Corsair TX750 PSU
http://www.amazon.com/Corsair-Enthu...d=1369600550&sr=1-1&keywords=corsair+750w+psu
LG Electronics 14x blu ray writer
http://www.amazon.com/LG-Electronic...=1369600929&sr=1-1&keywords=14x+blu+ray+drive
Corsair Carbide Series 300R
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139016
or you can pick out your own case from a huge selection from newegg or amazon
