I overclocked my i7 3930k up from 3.2 GHz to 4.5. I've got a Gigabyte X79-UD3 motherboard with the latest beta bios (F12p) and all I did to overclock was change the multiplier from 35 to 45 and increase the voltage to 1.34 volts (per Intel's 3930k info page). I also changed XMP settings to 'Profile 1'.
I'm still experimenting with voltages (trying to go as low as possible) but one thing that seems to keep happening --- regardless of my voltage --- is that after about 5 minutes of running Prime 95 CPU-Z will show the frequency drop from 4500 MHz down to 3200 MHz for about 5 seconds, then jump back up to 4500. This seems to happen once every 30 seconds or so. While this is happening, the Task Manager window in Windows 8 always shows 99% utilization, which then returns to 100% with the return to 4.5 GHz.
The only other problem I'm having has been blue-screening with the error "clock watchdog timeout", but I assume this is from having the voltage too low as I try to find that sweet spot.
Aside from the settings I listed above, I didn't touch anything else in my Gigabyte bios. It's all set to the default settings (mostly 'auto'), so things like TurboBoost are on.
Thanks!
Thanks!
